It is currently Sat 23. Nov 2024 10:07:04
 Post subject: trex 600 n
PostPosted: Mon 18. Jan 2016 7:38:45
Hi I have a spirit 1.3 on a trex 600 nitro. and want to install a spirit pro with a spectrum dx8 and 2 satilites. I have read all and need a detailed diagrams. word don't make any sense . I have a blade 450x with 1.3 standard spirit, only self level and ordinary, no resque. Please help :?:
 Post subject: Re: trex 600 n
PostPosted: Mon 18. Jan 2016 8:39:48
Hi!
Everything is same as for Electric helicopter.
There is only difference, that instead of an ESC you have to connect Throttle servo to the AUX1 port (if you are not using external governor).
If I can help you more, feel free to ask.
PostPosted: Tue 19. Jan 2016 22:35:49
With the new pro I would like to use stab.recovery,align and governor. With dx8.
PostPosted: Wed 20. Jan 2016 19:05:04
Hi John,
well, what you wish is very dependent on your setup.
So we have to continue step by step.
First from all, I recommend to start with setting of Spirit unit with your heli.
You have to get into the state when it flies well. At this step you can set throttle curves in your transmitter that it will fly quite nice even without governor.
At this step it could be good to setup governor.
So you have to modify the sensor connector to plug it in the unit. Servo connector crimping tool will be needed or at least soldering iron.
In the meantime you can also set the rescue/stabilisation. All of this must be done gradually, not everything at the same time.
So tuning and configuration can be more easy.
We can start with the wiring now.
Firstly, what BEC or power supply do you want to use? Is it Align 2in1?
PostPosted: Thu 28. Jan 2016 5:18:22
I am swapping out a spirit to spirit pro on same heli. Can I just install pro and download saved file from spirit into the new spirit pro. John. :!:
PostPosted: Thu 28. Jan 2016 8:07:19
Yes, you can do it in this way.
You have to only verify if sensor compensation is working correctly and then if Piro Optimization is configured well.
Users browsing this forum: No registered users and 17 guests
