It is currently Fri 22. Nov 2024 8:22:50
PostPosted: Sun 13. Dec 2015 21:01:45
Wintertime, perfect to have a closer look on the HW and played with vibration analysis. The tool is just great, thanks a lot. :D
My Wish:
RPM instead of Hz (rpm = Hz *60) on Axis,
General output with peak sum (xyz), allowing drill down into xyz on demand.
I did a vibration analysis and was impressed how easy I could get ridge of tail vibration.
rpm 2100 (35Hz) / Gear 8.85 (309Hz Motor) / Tail 4.8 (168Hz)
Took Main Blades of and released tail servos to move free.
I did start with a 60 Peak on Y-Axis
I did add some tape on one tail blade (around front edge in the middle/center), ending with 120 peak, so wrong blade.
Moving it to the other blade, got better results.
Making it smaller, thinks look great now.
PostPosted: Sun 13. Dec 2015 21:08:47
You can already display exact RPM by mouse anywhere in the plot.
PostPosted: Sun 13. Dec 2015 21:21:45
Yes I know, some other Manufactures show Hz as well, but we all run and think on rpm as many other rotation systems, this would just make it easier and better 8-)
You could even ask for Tail ratio to highlight and name peaks running on Spirit governor, this would be cool, but I guess you have other priorities.
Users browsing this forum: No registered users and 10 guests
