It is currently Sat 23. Nov 2024 8:38:11
[ 2 posts ] |
Tfmcnellis
Posted: Tue 08. Dec 2015 17:09:38 |
I am transitioning to Jeti. I will be using the Spirit Pro. My question is can I use the 3R/RSW on my helis. The only telemetry I want to using is for the main lipo. Can this be done with the 3R/RSW? If not should I look at one of the REX receivers.
Posted: Tue 08. Dec 2015 17:55:58 |
Jeti Integration will work with any EX Bus compatible receiver. But receivers, that are equipped only with one EX Bus port are not able to handle telemetry sensors and integration at the same time. So you can choose only one function - Integration or Telemetry from sensors.
Generally there are some telemetry data from the receiver itself, if it is enough for you, then both will work together with R3 too. But if next sensor is connected, then there is problem here.
In case of new REX receivers it is possible, because there are 3 EX Bus ports, so the unit is connected to one port and additional sensors to the rest. For example REX6/7/12 can be used for this purpose.
[ 2 posts ] |
Users browsing this forum: Bing [Bot], Google [Bot] and 26 guests |
