It is currently Sat 23. Nov 2024 8:15:28
 Post subject: goblin 500 tail wag
PostPosted: Sat 05. Dec 2015 23:00:15
Hi Guys, starting to figure out the ins and outs of the Spirit Pro, but I'm not sure where to go on this one, I've tried few adjustments but no luck.
I have a Goblin 500 pretty much stock had an IKON on it rock solid, with the Spirit I get a gentle 10cm tail wag back and forth any ideas?
thanks a bunch
Angus
 Post subject: Re: goblin 500 tail wag
PostPosted: Sat 05. Dec 2015 23:18:53
Correct tail servo frequency?
Correct mechanical setup, 3 or 4 degrees "negative" tail pitch when servo is centered?
Tried playing with tail gyro gain?
PostPosted: Sat 05. Dec 2015 23:31:06
Most probably the problem is in the mechanical settings.
Each FBL unit is more happy with different settings.
For Goblin I recommend 3-4° rudder pitch (tail slider closer to the boom),
then very important is Piro Consistency parameter.
I don't know what is your servo, but it should be somewhere around 175.
Rudder Delay (again, don't know what is your servo), but value of 5 could be good for start.
Gyro Gain may be very different between units.
PostPosted: Sun 06. Dec 2015 1:12:29
Align DS655 servo frequency specs is 300 so do you go up to 333 or down to 200? I will check my mechanical, thanks for the replies
Am
PostPosted: Sun 06. Dec 2015 5:51:46
Am
In theory you should go down.
But you servo is 333 according to the BeastX table, so you should be ok from that point of view.
http://wiki.beastx.com/index.php/The_BE ... vo_list/en
PostPosted: Mon 07. Dec 2015 7:27:09
I have that same servo running on my Spirit on a G500 also at 333
Sent from my Nexus 7 using Tapatalk
Users browsing this forum: No registered users and 52 guests
