It is currently Sat 23. Nov 2024 8:35:43
 Post subject: Dx8 rescue setup
PostPosted: Sat 14. Nov 2015 21:58:22
Im a new spirit owner (regular red casing) and will be installing this on my goblin 380 build that ill be starting shortly. I would like to setup the rescue on my gear switch if possible (outside lower left switch). That way I dont have to take apart the radio to switch the bind and gear switch or not be able to use the original hold switch. I have my hold and flight modes on theie normal positions. Is there a way that I can get this set up?
 Post subject: Re: Dx8 rescue setup
PostPosted: Sun 15. Nov 2015 0:21:45
You'll get the idea here:
http://www.helifreak.com/showthread.php?t=718597
PostPosted: Thu 19. Nov 2015 1:14:36
Yah I've read that but I was hoping I could just use the gear switch to activate the rescue instead of having to take my tx apart and whatnot. Has anyone done this yet?
PostPosted: Thu 19. Nov 2015 9:52:03
As I wrote, go to that link and get the idea.
Then use it for whatever switch you like.
PostPosted: Thu 03. Dec 2015 18:48:34
Just like Alyon187 stated, I too cannot figure out how to use the gear switch to activate the bailout/rescue function. When you go into switch assignment, there isn't an option to assign anything to the gear switch. I want to keep the trainer/bind button as it is because I use it for a flight timer. I was able to get the gyro function to work with the Aux3 knob. But, if there is a way to make this work with the 'Gear' switch, I am not seeing it. Anyone? Perhaps someone has another idea?
PostPosted: Thu 03. Dec 2015 21:41:13
Its mislabeled, the gear switch is actually the mix switch in your options.
PostPosted: Fri 04. Dec 2015 9:18:46
Sweet! Thank you very much. My Spirit Pro just arrived today.
Up till now, I have had a BeastX and an IKON. Hoping for the best.
Users browsing this forum: Bing [Bot] and 40 guests
