It is currently Sat 23. Nov 2024 8:23:56
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Spektrum satellite
PostPosted: Sat 21. Nov 2015 12:47:20
Yes, ground is shared. But you should disconnect red wire in the Spektrum plug.
Next week we will get AR7700 so we will check the compatibility. If there is any problem we will sort it out immediately and I will send you updated firmware.
You can change channel order in the unit for PPM.
PostPosted: Sat 21. Nov 2015 13:15:07
Wow, thank you, great news. I don't want to mess with ppm, until that i changed back to 2 sats. I wanted to use the ar7700 to get telemetry data. Thank you for checking compatibility with the AR7700. do you need me to send you mine? or you buy one anyway to check?
thank you!
Another topic, now i changed the rail 106 to rail 116 on trex 700 DFC, it is night and day. All tail bounce back disappeared, holding in tic toc like stone! Seems at 1950 rpm it needs the longer tail blade.
PostPosted: Sat 21. Nov 2015 13:17:26
We will receive new AR7700 on tuesday. So it is not necessary to send it. Thank you
PostPosted: Tue 24. Nov 2015 16:33:14
helo :)
Did you guys have a chance to try with AR7700 SRXL?
Thanks!
PostPosted: Tue 24. Nov 2015 17:19:59
We are still waiting for delivery.
PostPosted: Thu 26. Nov 2015 15:40:08
Hi!
Any progress? :)
Thanks!
PostPosted: Thu 26. Nov 2015 15:51:13
Yes, we have received AR7700 and are starting with tests. So in few hours I will inform you.
PostPosted: Fri 27. Nov 2015 18:04:44
Hi!
Any good news? :)
PostPosted: Tue 01. Dec 2015 13:51:18
here is special firmware, that will make it work:
http://spirit-system.com/dl/fw/spirit-f ... ar7700.4df
It is 1.3.2 with only change for AR7700 to make new Spektrum SRXL protocol compatible.
PostPosted: Tue 01. Dec 2015 14:15:59
Thank you very much!!!!
Is it 101% safe to use it? it is going to be used on a t-rex 700, and a signal problem wouldn't be so good :)
Users browsing this forum: Bing [Bot] and 32 guests
