It is currently Sat 23. Nov 2024 8:30:12
PostPosted: Thu 26. Nov 2015 0:28:54
Hi
when I connect the batery motor start to a continuos bipping. Servos work but motor is bipping !
Strange because I tried the fbl spirit unit in another trex helicopter (that is fully operational, working great) and the same happens, motor start biping continuos !
I re upload the latest firmware version (1.3.2) but still the same problem
please, see the video https://youtu.be/8CG92jDKI6E
any suggestion?
thank you very much
PostPosted: Thu 26. Nov 2015 8:27:31
the problem is only in Throttle Range settings.
After recalibration of your ESC everything will be good.
Alternatively you can change Throttle Range - Min. and Throttle Range - Max. values in the settings of the unit (General tab).
PostPosted: Thu 26. Nov 2015 14:22:37
Done, working !!
any recomended range value for a trex 450L dominator?
throttle frequency?
thank you very much
PostPosted: Tue 01. Dec 2015 5:05:49
Hi
I have another problem related. Now I have throttle, but it dont stop at the lower position.
If I make the throtlle to the minimum travel it still have some throttle
I am using DX9 with sats.
In lower position at -150 the motor wont stop
in the sipirit is -60 +50
thank you
PostPosted: Tue 01. Dec 2015 12:39:41
in the transmitter you do not have to change value to stop the motor.
You can just change value in the software (-60 change to -65 or less).
This should solve the problem.
PostPosted: Tue 01. Dec 2015 14:51:18
So, adjust your TX end points or servo travel to achieve 0 - 100 in the Spirit Diagnostic tab.
Then calibrate your ESC to that if you can.
If the motor does not turn off, lower the Min value in the Governor screen, don't touch your TX anymore.
PostPosted: Thu 03. Dec 2015 12:57:07
solved
THANK YOU
