It is currently Sat 23. Nov 2024 8:01:47
PostPosted: Sun 22. Nov 2015 17:17:35
I have the following issue with my Spirit Pro.
To let my cyclic servos work in the same direction I have to revers CH2&CH3.
Now all cyclic functions are working in the wrong direction.
If I try to solve that issue I tried to revers X-Pitch and Y-Roll and the sensor tab but it seems that these functions are not working.
It doesn't make any difference. Pitch and roll are still working in the wrong direction.
Only Z-Yaw settings has an effect if I enable/disable that.
What can I do to solve that issue?
Or is it a bug?
Guido
Jeti DC14 REX7, EX-Bus, Goblin 500 Sport Combo
PostPosted: Sun 22. Nov 2015 17:43:42
you have to use Reverse in your Transmitter to get correct direction.
Using reverse in the Sensor tab does not affect how the swashplate will move when you move with the sticks, but only when model is moving itself.
What you only need is to achieve state that all 3 servos are moving together when moving with the collective pitch (direction does not matter).
If it is working, then you can change direction in your transmitter by reversing Pitch channel.
When it will work, then you can use Reverse in your transmitter to get correct Aileron, Elevator and Rudder movement.
When it is OK, then you can go to the Sensor tab and here you can use Reverse to get correct compensations when you move with the model.
PostPosted: Sun 22. Nov 2015 18:26:51
thanks for your quick help :-)
Guido
Users browsing this forum: No registered users and 53 guests
