It is currently Sat 23. Nov 2024 5:45:01
PostPosted: Sun 22. Nov 2015 10:08:38
Hi there, I just bought a Spirit Pro and am going through the setup. However, I'm stuck as the Spirit Software isn't the latest version. I downloaded v1.3.2 and it's sitting in my "Downloads" folder but the software doesn't see it. I'm asked to select an application to open the file but Spirit doesn't appear as an option.
Next step is what?
Regards,
Heliman550
PostPosted: Sun 22. Nov 2015 11:10:28
You need to also use the 1.3.2 PC software, it will then see the 1.3.2 firmware (versions should correspond).
In few words:
a) install this software in your PC
http://www.spirit-system.com/dl/setting ... -win32.exe
b) power on the Spirit and connect it to the PC and run the PC software
c) use the PC software to upgrade the Spirit firmware to this one:
http://www.spirit-system.com/dl/fw/spirit-fw-1.3.2.4df
PostPosted: Sun 22. Nov 2015 11:38:46
In few words:
Thanks for response. Already did this but now v1.3.2 is shown but doesn't open and won't uninstall either. Maybe it's a Windows10 issue?
Regards,
Heliman550
PostPosted: Sun 22. Nov 2015 11:58:58
You can try to disable your antivir or other protecting software, it could block it for unknown reason.
Users browsing this forum: Bing [Bot] and 25 guests
