ZeXx86 wrote:
If this will be really requested by pilots, we can add it in the upcoming version 1.4.
Yes !: I fly at low and middle rpm, and when doing the rescue flip, the tail of my logo 600 turns about 30° sometimes.
My tail blades are edge 105 , tail servo is RJX HV with the gain set at the max without tail wag during funnel, I have reduced the rescue pitch (50%) and the cyclic limits are at 160, the rescue negative gain is the same as the HL gain, but despite all of these settings, the tail do not hold well sometims, during the rescue flip.
I will try to lower a bit more the cyclic ring, but according to me , the best solution could be a new setting for lowering the rescue flip rate, used in combination with the acro delay adjustement.
