I just retry to make the 3 head speed working and still no success.
For those how are will to try to help me, I attached my spirit and esc setting and other info on tx and receiver model.
As coco66 ask, I did the proper travel adjustment on my tx.
Low travel adjust on my tx to match 0% in the spirit software is 59%
File comment: 0% on throttle
High travel adjust on my tx to match 100% in the spirit software is 69%
File comment: 100% on throttle
I increased the min max value in the spirit gov. tab until the esc beep for high and low value.
File comment: Travel adjust on the spirit gov. tab.
I did this calibration with a 0 to 100 throttle curve.
Once the ESC was calibrated, I changed the throttle curve to a flat 30% 70% and 100% as explain in the talon 90 user guide.
This should give me the following head speed of 2000, 2300 and 2600.
When I retry the motor with these 3 throttle curve, I am only hearing 2 of the 3 head speed. The idle up 2 never kick in.
All the above test was done using a JR xg14 TX with a JR RG731BX receiver. The receiver is connected with the xbus cable to the rudder port on the spirit unit. The Tx is set on xbus mode B and the ESC is connected directly to the spirit unit in the aux1 port. With this radios/receiver setup, the PPM port are disable when the tx is set on xbus mode B, so I do not have the choice to connected the esc directly to the spirit pro.
Just for fun, I have try to calibrate the ESC using the receiver only in PPM mode.
Low travel adjust on my tx to match 0% in the spirit software is 112%
High travel adjust on my tx to match 100% in the spirit software is 72%
Guess what, the 3 head speed are working.
So, my only conclusion is that the software does not send the 100% signal to the ESC. This maybe because I need to go as low as 69% on the tx high travel adjust to match the 100% in the diagnostic tab.
Sorry for the long post, but I wanted to give you as much detail as possible.
Thank you in advance for your help, I sorry if my English is a bit bad.
Note to spirit programmer, I am open to test a beta version in the spirit frameware.
I can also sent the spirit and esc seting file.
