It is currently Fri 22. Nov 2024 16:47:42
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: Scale setup
PostPosted: Tue 27. Oct 2015 18:11:20
After much testing, there is still problem.
1. Sometimes stop for a moment the even at full rudder. Rudder servo: Align DS650
2. While pirouette sometimes the heli self aileron direction overthrown. Governance must be strong opposition.
I don't know what setup.
Thank you in advance for your help.
File comment: Current setup
sp7.4ds [255 Bytes]
Downloaded 83 times
PostPosted: Wed 28. Oct 2015 10:16:05
Are you sure that the Pirouette Optimization is correct?
I understand that is is very hard to check it on the ground.
For example when you change rudder servo or rudder mechanics, it can be result for the opposite settings.
PostPosted: Wed 28. Oct 2015 10:50:55
The Pirouette Optimization setup correct. Do not every pirouette occur.
PostPosted: Wed 28. Oct 2015 14:02:52
Are you sure that CG is good?
This can cause this issue as well.
PostPosted: Wed 28. Oct 2015 14:03:57
Then tested the rudder servo ball farther.
PostPosted: Wed 28. Oct 2015 14:07:00
CG correct. Main rotor shaft vertical.
PostPosted: Wed 28. Oct 2015 14:08:14
The problem may not be that counterclockwise rotation of the rotor?
PostPosted: Wed 28. Oct 2015 19:38:28
This shouldn't be a problem.
Does it happen always only to one side only?
Where is your collective pitch when you are hovering? (approx. position)
PostPosted: Wed 28. Oct 2015 20:52:21
It occurs in both directions.
Hovering approx 4-5 degree.
PostPosted: Fri 30. Oct 2015 8:22:57
It really looks like there is wrong pirouette optimization direction.
This behavior exactly correspond with the state when it is configured in opposite direction.
How did you tested that it is configured properly?
Maybe after initial configuration you have changed Sensor compensation direction for Rudder - this will lead in the problem that it is reversed.
