It is currently Sat 23. Nov 2024 8:01:25
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon 26. Oct 2015 19:06:07
Hello
Is it possible to use a 3 blade head with the spirit because I have some problems with my Oxy 3 qube...
Best regards Joeri
Verstuurd vanaf mijn SM-N910F met Tapatalk
PostPosted: Mon 26. Oct 2015 22:23:58
yes, Spirit is working without any problem with any head.
You have to only set the unit with respect to the mechanics.
For example some rotor heads need virtual cyclic rotation to work.
Some rotor heads can work without any additional configuration.
Very important are blades. For example by using a plastic rotor blades you can get very, very bad results with FBL.
PostPosted: Mon 26. Oct 2015 22:41:31
I'm using the 3 blade head form Oxy of course on one of my Oxy's and I'm using Zeal carbon blades so that will not be a problem
PostPosted: Tue 27. Oct 2015 11:59:34
Could you describe your problem so I can help you?
PostPosted: Tue 27. Oct 2015 12:39:08
The governor doesn't react like it must do, it's like he has no power enough.. I have already tried to lower the pitch and try new lipo's.
I use the hobbywing rpm sensor and the sensor need 3.5V-8.4V and I use the side of the spirit for it that's 3.3v so maybe that's the problem but I don't see anything changing if I put it right in de spirit with a Y cable
It's like he is missing some power... But that is also not the problem I asked that in the Oxy topic on helifreak
PostPosted: Tue 27. Oct 2015 13:34:24
Can you take a photo of the RPM sensor connection? Especially from the Spektrum connector.
Important is that polarity is correct.
But this isn't a problem with 3-blade rotor head, so I should rename the thread.
PostPosted: Tue 27. Oct 2015 15:39:02
Not sure if that is not the problem
PostPosted: Tue 27. Oct 2015 15:39:47
PostPosted: Wed 28. Oct 2015 10:03:41
Your connection looks correctly.
Can you see anything in the Current RPM and Requested RPM in the software?
PostPosted: Wed 28. Oct 2015 10:14:41
those are booth the same and correct...
Users browsing this forum: No registered users and 46 guests
