ZeXx86 wrote:
it is very sad to see your helicopter.
Unfortunately boomstrike can happen without bailout as well - you only have to do same manouver. What's more, I am sure that the bailout flip rate was not changed at all between versions.
The reason for boomstrike may be even in too loose blades in your rotor head. With helicopter size 550 and smaller boomstrike is very, very improbable if it is configured correctly. You can imagine how the blade must be bent to do something like this. Especially with size of 380.
For example situation when RPM will be bogged, your collective pitch is extremely high and your cyclic angles are too high as well can cause, that blade will move even 90° in your blade holder. This combination probably happened and will always cause crash.
Unfortunately we really can't affect state and performance of any helicopter.
I hope you will fix the helicopter soon and check the reason for the boomstrike.
Tomas, will there be an update to control the flip rate though? Seems like it's a popular request. Or are there technical issues? Thank you.
Sent from my SM-N910T using Tapatalk
