It is currently Sat 23. Nov 2024 6:45:07
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2, 3  Next
 Post subject: [SOLVED] 1.3.1 failure
PostPosted: Thu 15. Oct 2015 1:43:11
I just attempted to flash my spirit flybarless and it failed. It's now dead. Is there a way to recover it? Please help...also, is there a way to recover my settings?
 Post subject: Re: 1.3.1 failure
PostPosted: Thu 15. Oct 2015 7:11:31
Don't be afraid, it can be recovered without lost of your settings.
Could you tell me, if the LED on your unit blinks at least for a short time when you connect the battery?
If yes, then it can be fixed in the new recovery mode introduced in version 1.3. very easily.
If no, then you have to use older recovery mode, which is described in the Guide that I will send you.
Did you installed the driver that is linked in the manual (in case of Mac) or from your Wizard (in case of Windows)?
Thank you
PostPosted: Thu 15. Oct 2015 7:15:08
I have a Mac. No light blinking my dear friend. Any idea what could have happened?
PostPosted: Thu 15. Oct 2015 7:16:07
I have to check if it blinks for a sec when I plug in. Not near it until tomorrow.
PostPosted: Thu 15. Oct 2015 7:19:34
Also, I did install a driver when I first purchased my spirit 5 months ago.
PostPosted: Thu 15. Oct 2015 7:39:59
Sometime (especially after OS update) the driver is rewrtitten or if you are using more FBL systems it can be this problem as well.
For basic communication it is working, but for the update it is unstable as in your case.
All in all it can be fixed always.
PostPosted: Thu 15. Oct 2015 8:55:59
Please help! What do I do now?
PostPosted: Thu 15. Oct 2015 9:00:24
You have to check if your LED blinks for a few miliseconds when the battery is connected.
PostPosted: Thu 15. Oct 2015 9:08:56
It does not as far as I can remember.
PostPosted: Thu 15. Oct 2015 9:10:01
I can't check for sure until tomorrow morning. Can you send me instructions for what to do in both situations?
Users browsing this forum: No registered users and 45 guests
