It is currently Sat 23. Nov 2024 12:28:21
Post new topic Reply to topic  [ 86 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Wed 14. Oct 2015 8:26:05
Yup the current rpm is lower as the requested in the software but if I measure the headspeed it's a lot higher then the software says
Verstuurd vanaf mijn SM-N910F met Tapatalk
PostPosted: Wed 14. Oct 2015 8:32:21
Did you double check your gear ratio settings? A discrepancy between the values you see in the Spirit software and what you see in an RPM meter could depend on that....
PostPosted: Wed 14. Oct 2015 8:32:59
The problem can happen, when response of the motor is very slow.
Thus you can improve it with increasing Throttle Frequency.
You can also try to set Very slow spoolup rate.
PostPosted: Wed 14. Oct 2015 8:35:31
I have the frequency on 333 so that's a problem spool up is possible I have it now on fast gear ratio is correct and motor poles also
PostPosted: Wed 14. Oct 2015 21:15:55
Joeri_Plees: Your previous post was deleted because of vulgar comment.
I have responded to your question by private message.
PostPosted: Wed 14. Oct 2015 21:19:14
Where can I find the software to downgrade the spirit it s**ks now !
Looks what is measured and the real rpm is 3950 [ASTONISHED FACE]
PostPosted: Wed 14. Oct 2015 21:23:57
Sorry !
PostPosted: Wed 14. Oct 2015 21:24:21
I have already responded to your question in the private message.
Please describe what type of sensor, what helicopter and motor you are using.
Can you check if the readings of the sensor are stable so you can see in the Current RPM that it holds within range of units?
Is your collective pitch at the center position when you are testing this?
If not, than this is very normal behavior, because governor has active feed forward feature. This is determined by the value of Governor Response parameter which you want to use in the flight.
After update from 1.2 you have to re-do governor settings, else it will not work properly with the same values.
Testing governor at the bench is meaningless in this sense.
PostPosted: Wed 14. Oct 2015 21:26:18
I'm using the lynx eox 4100kv motor the hobhywing 40a platinum esc and the hobbywing rpm sensor to I have tried 3 different rpm sensors no difference and before the update the first one was working fine
And why midstick my rpm must be 2400 if I ask not 3950 al the time ?
PostPosted: Wed 14. Oct 2015 21:30:38
By the way your settings of motor poles is very wrong for your motor. In this way it can't work properly.
It is very sad you are swearing on multiple forums while even the basic settings is not correct.
Your sensing divider should be configured to 3, not 6.
Users browsing this forum: No registered users and 37 guests
