It is currently Sat 23. Nov 2024 5:07:06
PostPosted: Wed 07. Oct 2015 21:37:58
Setting up spirit pro software/firmware 1.3.1 when making changes and saving banks the servos go crazy and i have to disconnect power any ideas scared of damaging my servos
Compass 7hv v2 spirit pro. Compass 7hv v2 spirit pro. Trex 550fl spirit. Heli-x sim. NeXt sim. Pheonix sim. Fms p51 1400 spirit. Coolice 2400watt psu. Pl6. Icharger 206. Peter lynn twister 5.6. Dx9. TM1000.
PostPosted: Thu 08. Oct 2015 7:18:57
could you tell me, what is your receiver type and if it happen when you turn off the receiver?
PostPosted: Thu 08. Oct 2015 8:30:23
I am using 2 dsmx sats wired direct to unit with a dx9
PostPosted: Thu 08. Oct 2015 8:51:53
Great, then can you try if the problem is there when you start the unit without transmitter?
PostPosted: Thu 08. Oct 2015 9:06:13
I will test without tx after work. Thanks. Thinking ahead without the tx on its not possible to set limits/pitch range would a work around be to setup with tx on set limits but then before i go to save the settings turn off the tx??
PostPosted: Thu 08. Oct 2015 9:09:34
I think they want to see if the servos behave like that when not "bound". Maybe that's what happens while you are saving banks, some re-initialization happens that "suspends" the bind. Just speculating ))))))
PostPosted: Thu 08. Oct 2015 12:57:00
I can confirm that. I got this in 1.2 too, but I dont know how to reproduce it. Same configuration 2x dsmx sats.
Servos just go crazy
DX9 - Chase 360 - Spirit
PostPosted: Thu 08. Oct 2015 15:47:25
Tested with tx off and no issues.. but how do i set limits and pitch with tx off ??
PostPosted: Thu 08. Oct 2015 16:00:45
You can use your TX without any problem all the time.
Does the issue happen each time?
PostPosted: Thu 08. Oct 2015 16:51:01
Yes each time i go to save when the tx is on they go crazy
Users browsing this forum: No registered users and 31 guests
