It is currently Sat 23. Nov 2024 0:15:50
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Fri 02. Oct 2015 8:36:20
ZeXx86 wrote:
We have implemented this feature for demand of the pilots so you do not need to use any sequencers now.
If you are beginner then you can save the helicopter faster and at the same it will recover to the normal position.
Sorry, but may be that a beginner will try inverted flight with a safe altitude, so no need to climb during 1,5 s before recovering the héli ? At worst, the heli will be too high during the recovery, and a beginner may lose the orientation of his heli, especially with small heli like 450.
Il you want to try inverted flight near to the ground, rescue in acro mode is better.
It is constructive criticism, not denigration ! :)
Logo 600 sx spirit, Diabolo 700 spirit pro, Jeti DS 14.
France.
PostPosted: Fri 02. Oct 2015 9:52:43
+1 for a submenu in which we can trim the time before recovering from inverted to skid down.
PostPosted: Fri 02. Oct 2015 11:49:21
Oh yes, +1 here too
PostPosted: Fri 02. Oct 2015 13:05:15
Yes, we will add new parameter to the settings so it can be configured.
PostPosted: Fri 02. Oct 2015 13:16:49
+1
Did two packs today with the new firmware.
I can understand the idea why this is done.
The guys with programmable radios can change behaviour how they want.
However if it's fixed in Spirit firmware, users can not. :cry:
For small helis 0 (=old style) or 0.5 Seconds would be perfect.
Otherwise they are sky high before the skids are down.
Not something beginners would like.
I hope this small change can be done quickly with for example v1.3.1 firmware.
Thanks!
PostPosted: Fri 02. Oct 2015 13:26:08
That's me, except I am practising inverted with an even smaller heli - a 300 size.
Thank you Tomas for making the change.
PostPosted: Sun 04. Oct 2015 20:14:32
PostPosted: Sun 04. Oct 2015 22:31:18
We have released 1.3.1 right now, where you can configure this exactly as you wish.
PostPosted: Mon 05. Oct 2015 5:43:06
Already done ???? :shock:
I downloaded the 1.3.1 software and went to the stabi page to see if it was true... (sorry... :D ) and yes, there is a new setting between 0 and 3 s now :D
Thank you very much !
France.
