It is currently Sat 23. Nov 2024 5:22:18
Post new topic Reply to topic  [ 13 posts ]  Go to page 1, 2  Next
 Post subject: 1.3.0 firmware file
PostPosted: Wed 30. Sep 2015 22:34:07
File is .4df instead of .bin, roughly 120KB instead of around 50KB, and no published checksum... sure?
 Post subject: Re: 1.3.0 firmware file
PostPosted: Wed 30. Sep 2015 22:35:04
I just flashed it... Going to the field right now. I'll let you know in
about 20 minutes
Sent from my XT1254 using Tapatalk
PostPosted: Wed 30. Sep 2015 22:43:26
Please check our release notes, you can find more details about the new firmware format here.
PostPosted: Wed 30. Sep 2015 23:04:54
It flies! Don't forget to re-enable your governor after the update.... And download the new software on your phone if you're using it
PostPosted: Thu 01. Oct 2015 14:52:54
Just wondering, did you unplug all the cables from the unit before carrying out the update?
PostPosted: Thu 01. Oct 2015 15:11:31
Nope... Just plugged in the USB cable
PostPosted: Thu 01. Oct 2015 16:39:34
OK I have downloaded the file but am unable to update the unit as the firmware update software is only looking for a .bin file.
There is no option to search for any other type.
Windows XP. Any ideas?
PostPosted: Thu 01. Oct 2015 16:41:32
You have to download and install also the new software.
Old software does not support new firmware format.
PostPosted: Thu 01. Oct 2015 16:47:21
OK will try this now.
PostPosted: Thu 01. Oct 2015 17:14:15
Updated successfully and Nitro governor set up again.
On the bench the first thing I've noticed is that the throttle servo still goes over to full throttle but it no longer pulses continuously when it gets there.
I'm using a Jeti DS16,do I need to update a file for this to work correctly?
Users browsing this forum: No registered users and 19 guests
