It is currently Sat 23. Nov 2024 4:19:27
 Post subject: Spektrums satellites
PostPosted: Fri 25. Sep 2015 22:47:17
I am wanting to use two Spektrum satellites. I have a DSMX and a DSM2. Can I use one of each or do they need to be the same type?
Thanks,
Tom
 Post subject: Re: Spektrums satellites
PostPosted: Sat 26. Sep 2015 9:39:29
In general (not only for Spirit) you cannot mix DSM2 and DSMX.
PostPosted: Sat 26. Sep 2015 11:04:47
Bind both in DSM2 mode.
PostPosted: Sat 26. Sep 2015 14:50:08
Yes, it could work if you will bind both in DSM 2 mode, but it is not recommended and can cause major problems.
PostPosted: Sat 26. Sep 2015 20:49:38
I will use two DSMX's and be done with it.
I will need this cable to complete the set-up? http://file.espritmodel.com/heli/electronic/spirit-spektrum-acablen.jpg Y/N?
Thanks guys!
Tom
PostPosted: Sat 26. Sep 2015 21:32:13
Yes, you will need this cable or compatible ones.
PostPosted: Sat 26. Sep 2015 22:57:29
You will not need a cable if you will be using the Spirit Pro )))))
PostPosted: Sun 27. Sep 2015 9:38:10
Coco,
It took me a year to finally get my spirit installed and now the Pro is coming out :)
I need to get a little use out of the original model I purchased.
As an aside, my case is gun metal grey, like the pro. Tomas, there's no difference in the red or grey original base models is there?
The pro does indeed offer many new and cool additions. Betting it will be a big seller.
Users browsing this forum: No registered users and 51 guests
