It is currently Sat 23. Nov 2024 4:27:33
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Thu 17. Sep 2015 7:57:05
In the transmitter you should not configure your aileron/elevator range at all. Dual Rates or similar functions will change only speed of the rotation.
But swashplate can get to the angles so it can bind somewhere.
Thus corrrect settings in the unit is necessary.
PostPosted: Thu 17. Sep 2015 19:31:43
So, just to make sure you understood me correct or viceversa -
I configured max values in cyclic ring now and programmed my pitch curve in my remote control to the max and min pitch values I want to have.
On aileron and elevator I have 100%.
Correct?
Many thanks!
PostPosted: Thu 17. Sep 2015 20:00:04
I think not.
Cyclic Ring to max without mechanical binding. (higher Risk of Boom strike)
Pitch for Aileron and Elevator to max. 12°, not higher like cyclic Pitch
Maximum Pitch set with Pitch Range in Spirit, not with Pitch curve in tx
Goblin 700C Red Carbon, Cool Kosmik 200, Pyro 800-48, MKS X8 HBL 850/880 HV, Spirit-Pro, Jlog2.6GW, GPS-Logger 2
Jeti DS-16 Red Carbon+REX7
PostPosted: Thu 17. Sep 2015 20:37:09
To be clearer: Ail, Ele and Pitch ATV or End Points set in the TX so to see -100 and +100 in the Diagnostic screen.
Collective Pitch range set in Spirit to achieve, say,+/-12.
Aileron/Elevator range (also called Cyclic Ring, I assume this is what is causing misunderstandings) set in Spirit to the maximum possible value without binding in any combination of sticks (same value as Collective Pitch range should be ok, you can go higher but you have more risk of boom strike).
PostPosted: Thu 17. Sep 2015 20:49:52
You´re sure?
I have 12,5° collective Pitch and if I set cyclic Ring also to 12,5°, the higher boom strike risk is already there.
Your description sounds, all under the max Pitch range for cyclic ring is fine, but it´s not true.
You can look everywhere, all setup guides for cyclic Pitch range is around 8°.
Why?
PostPosted: Thu 17. Sep 2015 21:50:49
I don't know about degrees. Neither the AR7200BX nor the Spirit talk about cyclic degrees
Personally, I would not even know ho to measure cyclic degrees exactly.
I just know that same value of Ail/Ele range as the one of Pitch range works fine.
And Tomáš said "the higher the better" - to a certain extent which is blade strike possibility,
PostPosted: Thu 17. Sep 2015 22:37:11
@coco66:: actually I think you hit the nail on the head. Missed this one. (Collective Pitch range )
Users browsing this forum: No registered users and 51 guests
