It is currently Fri 22. Nov 2024 11:52:39
 Post subject: Scale setup
PostPosted: Tue 15. Sep 2015 14:46:39
Question:
Recommended setup the 700 size, 5 blade scale heli?
Thank you for your reply.
 Post subject: Re: Scale setup
PostPosted: Tue 15. Sep 2015 14:47:46
No 3D, smooth scale flight.
PostPosted: Tue 15. Sep 2015 16:07:57
You should set Flight Style to 8, Cyclic Feed forward to 3-4. Rotation rates could be 8 or less and TX expos 25-40%.
More problematic is mostly rudder if there is heavy fuselage so more tunning may be needed then.
PostPosted: Tue 15. Sep 2015 18:21:20
Thanks. I will report on the developments.
PostPosted: Fri 18. Sep 2015 23:43:04
Video:
0:46 sec: This is what could be?
3:08 sec: Rudder discontinuous.
LOG VIEWER: no error
Otherwise a very good Spirit FBL system.
Thank you in advance for your response.
PostPosted: Wed 23. Sep 2015 15:47:55
Currently, using these settings:
Delete...
PostPosted: Wed 23. Sep 2015 16:14:15
Thank you very much for the photos.
You can save your profile in one file and send it here, so you do not have to take these shots at all.
It could be caused by heavy tail. In this case you may try to increase Piro Consistency even more or to set Revomix which should compensate it well.
For scale helicopters revomix is required probably in all cases. Maybe 3 points could be enough.
PostPosted: Thu 24. Sep 2015 18:47:32
Getting better. Thank you very much for your help.
Probably it will be a good setup:
700-800scale.4ds [255 Bytes]
Downloaded 145 times
PostPosted: Fri 25. Sep 2015 15:00:45
Thanks for your setup, it is OK.
PostPosted: Mon 12. Oct 2015 11:17:25
So now flying in stormy winds with Spirit system :) :
