It is currently Sat 23. Nov 2024 3:58:27
PostPosted: Sun 31. May 2015 6:47:31
Hi guys i would like to try the gov but am a little unsure on the voltage going in to the pit port. I am running a castle ice lite 50 using internal gov at the moment but going to try the spirit gov. I am using the internal bec at 5v please could someone explain how i conect this to my spirit. Am i right in thinking that if i connect the rpm sensor to the rudder port minus the signal wire and connect the signal wire to the pit pin i am good to go. Or do i need to put a step down on the signal rpm wire going to the pit pin? Hope i made myself clear thanks guys
Compass 7hv v2 spirit pro. Compass 7hv v2 spirit pro. Trex 550fl spirit. Heli-x sim. NeXt sim. Pheonix sim. Fms p51 1400 spirit. Coolice 2400watt psu. Pl6. Icharger 206. Peter lynn twister 5.6. Dx9. TM1000.
PostPosted: Sun 31. May 2015 10:22:54
we have tested that with HobbyWing RPM sensor you can use 3.3 - 8.4V without any problem as power supply for the sensor.
PostPosted: Sun 31. May 2015 10:27:30
Thanks does this mean i can just connect the signal wire from the rpm sensor to the pit pin and then connect the pos and negative of the rpm sensor to the rudder port
PostPosted: Sun 31. May 2015 11:15:11
Yes, it should work fine as we tested it.
We have updated the manual right now.
PostPosted: Sun 31. May 2015 11:49:31
Yes the way described here works fine and initial bench test look really good very easy gov setup excellent work tomas and the rest of the spirit team :D
PostPosted: Thu 10. Sep 2015 17:55:20
Hey,
which pin do i connect the signal wire to? The one that is shown on the picture (middle one) or the facing towards inside of the unit (the one for the signal).
PostPosted: Thu 10. Sep 2015 17:57:04
In the Spirit ELE/PIT/AIL port, the RPM signal should go to the middle pin.
PostPosted: Thu 10. Sep 2015 20:37:03
Yes middle pin
PostPosted: Fri 11. Sep 2015 6:43:53
Thank you both.
I know the picture in manual shows the middle pin, but i was kinda worried, because on all other pins, the signal is the one facing toward the unit, and normally all + and - are connected, so i was afraid i'd conect signal to +, and you know where that leads :idea:
Users browsing this forum: Bing [Bot] and 52 guests
