It is currently Fri 22. Nov 2024 2:20:47
PostPosted: Mon 31. Aug 2015 16:55:48
Just finished setting up my E5ss 716mm edge blades, I'm getting elevator bounce on quick inputs during hover. What parameter should I tune first?
PostPosted: Mon 31. Aug 2015 17:19:14
Elevator Filter, this is exactly the parameter which should be used for reducing the effect.
PostPosted: Mon 31. Aug 2015 18:26:49
I actually have it maxed out to 3 already and still getting the bounce.
PostPosted: Mon 31. Aug 2015 20:00:55
Max. value is 4 here.
What is your Cyclic Feed Forward value?
PostPosted: Mon 31. Aug 2015 20:19:35
Sorry, I got the bank 2 on 4 and bank 1 at 3 and bank 0 at 2 on the elev filter.
cyclic ff if I recall right is set pretty high:
b0 = 9
b1 = 10
b2 = 12
flight charac
b0 = 5
b1 = 6
b2 = 7
PostPosted: Mon 31. Aug 2015 20:35:49
If Cyclic Feed Forward is so high (no more than maybe 8), then servos are not able to handle such rapid changes. This is the reason why you observe elevator bounce even with high elevator filter value.
I recommend lower values there.
If you want faster cyclic reaction (in other way than CFF does), you may try to increase Geometry 6° value by 10-25 (even that then it will not correspond to 6° mechanically). Also decreasing Cyclic Gain can make the reactions faster.
So then your servos should handle it fine.
PostPosted: Mon 31. Aug 2015 20:37:57
Thanks! I'll Try that tonight.
PostPosted: Tue 01. Sep 2015 3:50:53
Tomas,
Here's my setup files.
I lowered the cff down to 3 and raised the elev filter 2,3,4 on 3 banks ( now the files attached have the elev filter down to 3 only but during flight I had it at 4 on bank2)
I now am getting aileron shakes after flying around on bank 2. I still am getting the elevator bounce on all 3 banks, but not as bad when I had the cff at 12.
I also have increased the cyc geometry by 15 counts from 6deg so its around 8deg now
on this setup I get tail bounce on right yaw stops.
By the way I'm running
7s 4100mah pulse 45c
yep 120hv on active freewheel
100% straight tcurv
-14/14 cyc and 12.5cyc
14t pinion
106mm tail with 54/12t
I know that with this battery I am tail heavy, can that be the cause of the elev bounce too?
Maybe put 12s or 2 6s in parallel to balance the heli?
P.s. the aileron shakes showed up on 7s, none on the 6s.
What gains should I change (higher or lower) when I change headspeed?
I am planning to run it on maybe 1600rpm and 1300 rpm.
I've read that on other FBL's the D gain is supposed to get rid of this elev bounce, Which parameter would that be on the spirit?
Arnold
E5ss Synergy e5ss 2015-08-29 DSM2 gov x9d radio b2.4ds [255 Bytes]
Downloaded 92 times
E5ss Synergy e5ss 2015-08-29 DSM2 gov x9d radio b1.4ds [255 Bytes]
Downloaded 95 times
E5ss Synergy e5ss 2015-08-29 DSM2 gov x9d radio b0.4ds [255 Bytes]
Downloaded 92 times
PostPosted: Wed 02. Sep 2015 15:55:52
Tomas,
Any updates?
PostPosted: Wed 02. Sep 2015 16:52:45
If there is wrong CG, then it can create such problems, especially with elevator.
So correcting this should solve your problem and maybe it can work with previous settings and any other tuning.
Parameter D you have mentioned is elevator filter. But if there is something really wrong, than it can't be fixed by this parameter.
You should have always good CG else you will need ultra fast and strong servos to make corrections fast enough.
Users browsing this forum: No registered users and 16 guests
