It is currently Sat 23. Nov 2024 5:29:06
 Post subject: Stick comand
PostPosted: Mon 24. Aug 2015 4:24:04
Whats the difference in Stick priority and Direction control rate for control of heli in stability mode flying thks.
 Post subject: Re: Stick comand
PostPosted: Mon 24. Aug 2015 7:35:19
In the stabilization mode, you can change Direction Control Rate which is changing how much you can control the helicopter.
With high values you can change the angle a lot.
PostPosted: Mon 05. Oct 2015 19:19:23
What does stick priority do then.
PostPosted: Mon 05. Oct 2015 20:20:47
With stick priority you are directly control the swashplate.
Direction Control Rate determine only rate of allowed change.
Users browsing this forum: Bing [Bot] and 22 guests
