It is currently Tue 11. Mar 2025 6:06:34
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun 16. Aug 2015 23:33:31
Yes assuming you know what headspeed you want to run.. I don't remember what helicopter this is on
PostPosted: Mon 17. Aug 2015 10:09:08
Nitro 700 size.
Curve set up and requested RPM used.
I have set the fully shut down throttle point at -40.
If this is at zero once you have added +sub trim to get the engine to idle it seems that you are getting too close to the 15% gov switch on point.
The throttle servo starts travelling towards full virtually as soon as you move the throttle stick.
As it is now there is stick movement before the governor turns on.
Users browsing this forum: Bing [Bot] and 7 guests
