It is currently Tue 26. Nov 2024 14:09:11
PostPosted: Sun 02. Aug 2015 14:39:42
I am thinking about putting Spirit FBL systems in my nitro Trex600. What governor sensor should I buy if I'm going to be using two Spektrum satellite receivers?
Larry
Sent from my iPad using Tapatalk
PostPosted: Mon 03. Aug 2015 15:55:45
Also what port does it get connected to, and how should it be powered?
PostPosted: Mon 03. Aug 2015 18:23:48
You can buy for example Align Sensor and Y-cable so you can power sensor from the Spektrum connector.
Check my attachment, please.
PostPosted: Mon 03. Aug 2015 21:28:51
Thank you for the information!
Can I run two spektrum satellites and the governor? What ports would all 3 go into?
Thanks Larry
PostPosted: Mon 03. Aug 2015 21:51:58
This Y-harness can be connected to the native satellite connector directly to the unit. Here you will connect one satellite and governor (only 2 leads for powering it). Signal wire from the sensor should go to the PIT pin in the unit.
Second satellite should be connected to the RUD port in the unit via adapter that can be bought in our eshop.
PostPosted: Mon 10. Aug 2015 4:44:42
Hi Larry, have you tried the gov on your nitro yet ?
PostPosted: Mon 10. Aug 2015 12:36:22
No I haven't, waiting on the governor sensor to come in the mail. I'll post as soon I do and let you know how it goes.
Users browsing this forum: No registered users and 11 guests
