It is currently Sat 23. Nov 2024 0:16:49
[ 6 posts ] |
walle999
Posted: Sat 25. Jul 2015 10:35:09 |
Hi there i have some problems with my spirit and jeti ds16 the thing is this:
when i change something in the radio i dont know if the spirit take the change as when i for an example change cyclic servo reverse in the menyes in my transmitter it does not happen anything when i move the sticks(stays the same as before) but if i do the same in the computer software the change is instantanius and work like i expect it to but not in the transmitter when i change
example 2 i change max head speed in govnor in tranmitter and tho it seems to be different when i fly my heli it does not change when i use the pc software to read out the data.
example 3 when i change the pitchrange in the transmitter IT DOES change in the pc software
example 4 rotation speed does not always change but most often(might be me sometimes who forget to save)
ps ALL the things i change in pc software change in the tramsmitter so far as i know
Info: Red spirit only a few month old(latest firmware 1.2.1) Logo 600sx v2 Scorpion 4035 HKIII 560kv Futaba bls 451 and 251 servo Castle creation edge 120a jeti DS-16(latest firmware 3.02) REX 7 reciver with ex buss and no telemetry sensors ATM
The heli fly and im in to fine tune it but there the problems begin.
Posted: Sat 25. Jul 2015 11:12:57 |
settings in the unit should be instant always except for the important parameters that you dont want to change during the flight (for example servo reverses). If you are changing something, you can refresh the menu screen on the transmitter to be sure that the settings are in the unit. But it should work always without any troubles.
You should always save the settings to the unit else it will be lost when the power is disconnected - maybe here is the problem?
I recommend to not use PC software and Jeti configuration at the same time as it can cause more confusion.
walle999
Posted: Sat 25. Jul 2015 12:22:20 |
I susspected that it could be so. I will double check but i think this is the problem. Another thing does the max head speed in gov is it the max head speed that i would get witout gov that i sould put there like around 2500for my 12s setup? And then set trottle to achive the rpm i wanted like 2200rpm. Or do i set max rpm in gov to 2200 and set trottle to achive 2200rpm
Eury
Posted: Sat 25. Jul 2015 13:21:43 |
I see the exact same behavior in my Spirit with some settings through the Jeti. Just yesterday I was at the field and wanted to drop my pitch range down. Nothing I did would make it save that setting. Refreshing it did nothing to make it save through a power cycle. Ended up giving up and bringing home to hook to a computer.
Sent from my iPad using Tapatalk
walle999
Posted: Wed 29. Jul 2015 19:17:30 |
was outside today between the rain, and tested and it seems that you where right for me as the spirit took all my settings thanks for the help
//Niclas
Posted: Thu 30. Jul 2015 8:19:09 |
Perfect, thank you very much for the info.
[ 6 posts ] |
Users browsing this forum: No registered users and 55 guests |
