It is currently Tue 11. Mar 2025 6:05:24
Post new topic Reply to topic  [ 13 posts ]  Go to page 1, 2  Next
 Post subject: Rsat2 connection
PostPosted: Fri 12. Jun 2015 21:23:09
Can I just check I understand this correctly?
To run UDI with a Jeti Rsat2 I connect to the EXT port but Jeti instruct not to add power to EXT.
I don't want to damage the RX.
"Connect the unit with special cable - you can made it yourself with included ELE/PIT/AIL cable in few seconds (check attachment).
One end of the cable should be connected directly to the EXT port. Opposite end has two connectors. One with power supply wires (RUD port) and one with signal wire only (ELE/PIT/AIL port, respectively AIL pin)."
Mark.
 Post subject: Re: Rsat2 connection
PostPosted: Fri 12. Jun 2015 22:56:16
EXT connector is used for EX Bus connection or telemetry sensor, not UDI.
You have copied phrase from EX Bus connection that allows integration with the unit and JETI transmitter.
UDI is different connection type that does not allow it, but connection is easier - just normal cable.
PostPosted: Tue 14. Jul 2015 21:29:27
Yes, I found the different information very confusing but got there in the end.
Flew my 600 pro at the weekend with basic settings and only changed the flight style to 7 which suited my flying and felt more like the Vbar I removed.
Have to say, the heli was rock solid and very smooth, I'm very pleased with how it flies and the ability to quickly change settings without a laptop at the field.
Big thumbs up from me. :D
Mark
PostPosted: Wed 15. Jul 2015 6:56:00
Mark, from reading between the lines I assume you are now using Exbus? Have you checked your Failsafe? Known issue at the moment with Exbus and Spirit.
PostPosted: Wed 15. Jul 2015 7:25:18
Thank you very much for the info!
PostPosted: Wed 15. Jul 2015 22:20:55
Correct I have test flown this with Exbus and failsafe did not cut the motor. Will be changing this for future flights until a fix is available now that I know it flies well. Hope something comes soon.
PostPosted: Wed 15. Jul 2015 22:44:10
Small update to address the issue will be released this weekend :)
PostPosted: Thu 16. Jul 2015 20:40:52
That would be fantastic, I will hold off changing anything.
PostPosted: Sun 19. Jul 2015 19:46:37
Hi Tomáš,
I found that new fw 1.2.1 was released, but changelog hasn't updated?
Could You please chime what fixes this new minor update contains:)
Sami
PostPosted: Sun 19. Jul 2015 19:47:37
you can find changelog here on the forum in News/Version 1.2.0 released and also in the software after updating to the latest version.
Users browsing this forum: Bing [Bot] and 5 guests
