It is currently Sat 23. Nov 2024 0:07:36
Post new topic Reply to topic  [ 14 posts ]  Go to page Previous  1, 2
PostPosted: Mon 13. Jul 2015 23:36:23
ZeXx86 wrote:
ajw068:
This is wrong - when rescue is really activated, it does not matter at all where the sticks are.
You have to see HF in the diagnostic tab if the rescue is really activated. Any channel should not change its value except Gyro Gain when the rescue is active.
Ok I'm seeing HF when I switch the banks on my computer. When I switch the transmitter to bank 2 nothing happens on computer screen. I'm assuming this is because it's connected to computer.
As far as throttle hold I think I have that sorted out.
PostPosted: Tue 14. Jul 2015 17:39:06
You are right, banks can't be switched from your transmitter when the software is connected. Altough you can switch banks in the software by changing Bank ID.
PostPosted: Mon 27. Jul 2015 2:08:01
ZeXx86 wrote:
ajw068:
Problem solved!! I ended up using bank 0 for rescue and thats it. The whole time I was thinking I needed all the banks but really all i needed was the rescue. I figured it all out and now it works flawlessly. I'm so happy and confident now to fly and be more aggressive knowing that I can bailout in a split second. I tested the rescue several times and its unbelievable. Thanks for making such a great affordable product!
Art.
PostPosted: Mon 27. Jul 2015 18:02:39
Thank you very much for your post!
We are also very happy :)
Users browsing this forum: Bing [Bot] and 51 guests
