ZeXx86 wrote:
If I understand right your Banks are switched by Gyro Gain in the transmitter so the Gyro Gain function in the General/Channels is unassigned.
In this case to activate the rescue you have to set negative gyro gain in the Sensor Tab. For example to -60. Then when bank is switched you will see HF in the diagnostic tab instead of HL.
That is all correct so far.
A couple more questions.
1. When my stick is just above mid stick on transmitter and when I activate rescue the swash plate goes down? Is that normal? When it is mid stick and below the swash goes up.
2. On the diagnostic tab the pitch slider is backwards from what it does on the heli. When I pitch up the slider bar goes down to negative and when I pitch down the slider bar goes up. However the pitch is correct on the heli in the right direction.
3. On the diagnostic tab when rescue is activated the throttle tab goes from 35% down to 14%. Is this normal?
4. I haven't touched anything on transmitter as far as throttle cut/ throttle hold etc. should I be changing something?
Thanks.
