I have a similar wish!
Ive just moved over from Beast X to Spirit because of the stability and rescue modes.
I have a DX18 and have physically moved my radio's momentary / bind switch out to the LH corner for easier access.
I initially used the Spektrum setup guide to setup my Logo 600 with the 'Hold' flight mode / rescue being activated by the momentary bind switch (selects negative rudder gain for rescue).
However I thought it would be great though if the radio could be setup to fly in stability acro mode (for practising new manoeuvres and inverted flight) but still be able to press the momentary switch for rescue? Kinda like my Blade CP S and 230S.
I was thinking this could maybe be done by setting up;
- First flight mode (0) with a negative rudder gain value (and have Bank 0 setup for flying around in stability / acro mode but sports flying pitch / throttle curves)
- Second flight mode (1) as a positive gain for normal sport flying (cant cheat all the time
) but somehow still have rescue available through the momentary switch
- Third flight mode (2) with a negative rudder gain value (and again have Bank 0 setup for stability / acro mode but 3D pitch / throttle curves) Im very new to 3D so wouldnt mind the stability assistance for a while!!
Now with the Spirit;
- Bank 0 as stability / acro mode
- Bank 1 as Rescue but the bank change selected through the momentary / bind switch from any of the flight modes?
I presume that as the helo would be running negative gain in the first Flight Mode (0)and FM 2 it should easily transfer from the stability/acro bank (Bank 0) and go to rescue mode (Bank 1) if bank switching is selected through the momentary switch?
What I'm not sure of though is that it will be possible to have the momentary switch still activating rescue for Flight Modes 1 when the helo is running a positive rudder gain value?
Maybe through a mix to reverse the rudder gain if the momentary switch is pressed whilst in FM 1??
Has anyone had any success in setting up their Spektrum (particularly DX9 or DX18) like this?
Thanks for any advice!
