It is currently Sat 23. Nov 2024 19:57:43
Post new topic Reply to topic  [ 15 posts ]  Go to page 1, 2  Next
PostPosted: Tue 16. Jun 2015 23:27:34
I have a Futaba 14SG. I have channel 7 on my radio set to Aux1 to SG switch.
Bank 0 I have Rescue.
Bank 1 I have Stabilisation mode.
Bank 2 Disabled.
Also have IDLEUP3 to switch SH.
So if I fly with switch SG down, which is Bank 0 with Rescue, doesn't
that mean that rescue is on all the time?
or do I fly with SG switch up to Bank 2 Disable and than hit swithch SH when Rescue is needed?
 Post subject: Re: Banks
PostPosted: Wed 17. Jun 2015 16:12:59
This depends on when you are switching to negative gyro gain.
Only negative gyro gain can activate special function thus as the rescue or stabilisation modes.
You have to be always in Bank 1 if you want to be able to activate the rescue.
Maybe you want to check our Futaba guide where you can find necessary information.
PostPosted: Wed 17. Jun 2015 16:57:46
Thank you for replying.
I have read your Setup Guide for Futaba several times over. Everything is always easy once you know how to do it right?
Okay I understand what your are saying. Let me see if this is right.
I am flying around and my radio switch is in Bank0 that is set for Rescue. To activate Rescue, I momentarily hit switch SH and that will activate Rescue
because it has a Gyro setting to normal rate of 60 (-60)correct?
PostPosted: Wed 17. Jun 2015 20:36:01
Yes, you are correct.
PostPosted: Wed 17. Jun 2015 22:20:37
Thank you sir for replying.
My next question.
Now lets say I want to try Bank1 which is set to stabilization. Do I have to fly holding the SH switch because it is a spring loaded switch
or do I have to select a different switch?
PostPosted: Sat 20. Jun 2015 1:53:46
I have figured it out for those who want to know. I had to change the SH switch to a 3 position switch so I could use Stabilisation without having to hold the SH switch.
PostPosted: Tue 23. Jun 2015 8:22:13
hi,
you can use a logic switch with the T14 SG, to active iddle up 3 with SH (momentary switch) for the rescue mode, or with any other switch you want for the stabi mode. Both switch can active iddle up 3.
You can choose and set your bank switch to activate iddle 3 only when you are in stabi mode bank, and when you are in rescue mode bank, you can activate iddle up 3 with SH, (momentary switch):
Switch for iddle up 3:
LOGIC
SH OR SB (bank switch for me)
Logo 600 sx spirit, Diabolo 700 spirit pro, Jeti DS 14.
France.
PostPosted: Tue 23. Jun 2015 14:38:19
Thanks. I will look into it to see how it's done.
PostPosted: Tue 23. Jun 2015 21:26:23
this is for icare.
Can you explain the process on how to get switch SG to turn on Stabi and Idle3?
I already have SG set to Stabi on position 2.
Joe
PostPosted: Wed 24. Jun 2015 8:39:16
I will try do do that , it is no so easy with my poor english...
When you choose a switch for idleup 3 condition, you must get this display on your TX:
Screen 1 :
switch
single
You must change single by LOGIC and you will get this display:
screen 2 :
switch
LOGIC
-- AND --
First: you choose sh, with :
OFF
ON
Second: you change AND by OR
Third: you choose SG (which also change the banks) with:
OFF
ON
OFF
Normally you must have the bank with stabi mode and idle up 3 activated when SG is in the middle position (position 2) and you can still activate idleup 3 with SH if you need it, when SG is on position 1 or position 3 to select the others banks.
You can verify in Diag tab that SG in position 2 activates the stabi bank and idle up 3 (negative value for gyro )
Take care to not start up your motor if you make some test on the bench !
I hope it will help !
France.
Users browsing this forum: Bing [Bot] and 60 guests
