ZeXx86 wrote:
For some people this issue is happening when throttle is not calibrated correctly.
What is value of the throttle in the diagnostics tab, when there is 0% TC?
Do you see Requested RPM correctly?
Also you may try slower spoolup rate.
I checked the diagnostics tab again.
It's perfect and spot on!
Using a linear TC from 0 - 100%, stick all down is a 0 on diagnostics.
Stick a tiny bit up and you see the diagnostics climbing as well.
Stick all the way up and diagnostics goes to 100% as well.
I can't get this any better.
And yes, requested RPM is exactly as expected.
If I let it run briefly, it also shows actual RPM.
Oh, I'm bench testing with a 3S lipo, if that matters.
Flight lipo is 6S.
Again I had a very high headspeed on spoolup.
Switching briefly to Stunt1 and back to Stunt2 solves it.
I'll try slower spoolup again (Governor Mode - Electric), because this is very annoying.
I don't recall I had this issue with "Governor Mode - Electric". We will see.
While flying for sure it did more hunting with 4 - 4, compared to 3 - 3.
Very handy using bank switching for testing!
