Spirit System
Solved Pitch range changes
https://www.spirit-system.com/phpBB3/viewtopic.php?f=35&t=4225
Author:  morrchew [ Tue 18. Aug 2020 4:31:15 ]
Post subject:  Solved Pitch range changes
[code][/code]I have set up many Spirits and this one has me beat I set up all parameters in the setup to 12 degrees + and - . 6 degrees is good and I do get 12 degrees when wizard is open I saved all settings . Power of heli, power on heli set stick to positive pitch and I get 15 degrees positive 15 Negative what’s wrong . Plug spirit back into USB and all is 12 degrees .why is it changing . This is Spirit v2 and 2.8.0 firmware . I have 23 spirits and all other Helis work fine . What do I look for or is the unit faulty it’s A new unit and first install
On a Goblin Urukay three blade .
Author:  ZeXx86 [ Tue 01. Sep 2020 15:00:34 ]
Post subject:  Re: Solved Pitch range changes
very likely you have multiple banks. And you configured unit only in the Bank 0. When Spirit Settings is opened, then Bank 0 is selected automatically. So it is enough to set other banks in the same way - especially Collective Pitch range - see Bank Comparison.
http://www.phpbb.com/
