Spirit System
Using separate flap and aileron
https://www.spirit-system.com/phpBB3/viewtopic.php?f=35&t=4177
Author:  The Da [ Mon 27. Jul 2020 13:42:44 ]
Post subject:  Using separate flap and aileron
From the manual, it seems that when flaps are used with a standard spirit, they get automatically mixed with the ailerons and output to Ch1 and Ch3. Is it possible to have the flaps not mixed and output to a separate channel of the spirit? Like having ch1 for ailerons, ch3 for flaps and ch2 & 4 for elevator and rudder per the manual. This is when using a receiver witth a single line connection like the spektrum 4649T where no rx connections are available to drive servos directly. Also, Aux is to be used for throttle per the manual.
Author:  ZeXx86 [ Mon 27. Jul 2020 18:12:58 ]
Post subject:  Re: Using separate flap and aileron
with Spirit 2 or Spirit Pro you can assign a free channel to F: Output to AUX2. This can be used for flaps too.
So flaps will be connected at the AUX2 port.
Author:  The Da [ Mon 27. Jul 2020 19:12:18 ]
Ok so it is not possible with standard spirit which is what I already have.
It would be nice to have that as a future firmware upgrade as it would allow standard spirit to be a real 6 channels system (one being used for gyro gain).
http://www.phpbb.com/
