It is currently Fri 22. Nov 2024 3:02:58
[ 2 posts ] |
rotorhead51
Posted: Fri 01. May 2020 1:35:24 |
I have a E-Flite f4u Corsair and would like to know if it is recommended to mount directly to the foam with the supplied double sided tape, or would it be better to glue down a thin plywood base first then use the double sided tape to mount the Spirit Aero unit? The foam base seems too soft to mount directly to, just need some clarification. Thank you.
Posted: Thu 25. Jun 2020 19:51:37 |
it might work in both cases. So if it easier to use just double sided tape, you can try it. Mounting it more firmly will give a better results anyway. In the worst case it could induce some oscillations when flying.
[ 2 posts ] |
Users browsing this forum: No registered users and 12 guests |
