It is currently Thu 21. Nov 2024 20:27:55
Page 1 of 1
[ 4 posts ] |
Author |
Message |
bell222
Posted: Thu 28. May 2020 10:37:15 |
in the manual it says to set the rudder to motor for esc driven tail were do i go to do this
Top |
yufasa
Posted: Thu 28. May 2020 11:17:55 |
I must confess that I did not find the setting either but I don’t have a uSpirit and there may be a special setting for it. Here are a few notes that may get the conversation started:
“ With µSpirit units it is possible to enable support for the tail rotor driven by dedicated motor. In this case two ESCs are used, where Rudder ESC is connected at the CH4 port. Important thing is to set Limits/Rudder ESC - range appropriately since these are defining available Throttle range for the ESC from 0 to 100%. Normally this parameter is available in the Setup Wizard.”
I can however point out a few things:
1) The servo setting tab: Leave the rudder “servo” setting at default settings of 1520us and 50hz 2)Limits tab: Micro helicopters and µSpirit: When Tail rotor is driven by a dedicated motor, the Rudder ESC must be connected at the CH4 port. Rudder end-points are then used to set available Throttle range for the Rudder ESC from 0% (Stop) to 100% (Full). We recommend to set Stop limit to 126 and Full limit to 150 for the beginning.
Top |
bell222
Posted: Fri 29. May 2020 6:21:47 |
this is for a 60 size heli useing spirit pro does that make any difference
Top |
Ricad
Posted: Sun 05. Jul 2020 1:46:59 |
Joined: Wed 17. Sep 2014 2:17:53 Posts: 8 Location: Khancoban, NSW, Australia
Ron, you put his in the Aero section. Should be in the Heli section.
Top |
Page 1 of 1
[ 4 posts ] |
Who is online |
Users browsing this forum: No registered users and 17 guests |
