It is currently Fri 22. Nov 2024 1:07:28
PostPosted: Tue 05. Dec 2017 18:11:59
Hi, i read the manual but i am not sure which cable i really need for the most simple solution... :?
I have a spirit black edition, an frsky x4r receiver, a hobbywing V4 60A, and i want to have the telemetry of the Voltage of my lipo.
I think i only need the integration cable... is it true? or should i need the the telem uni cable too? :roll:
Thks.
PostPosted: Tue 05. Dec 2017 20:09:58
Oups... sorry it is in bad section the question is for spirit heli not aero...
PostPosted: Tue 05. Dec 2017 22:39:26
You can use external port of the receiver for measuring battery voltage. But you will need a voltage divider as the max voltage is limited.
More info for example here:
https://www.youtube.com/watch?v=4ezXup0BqEE
Or if you want full Telemetry and Integration with Taranis, you will need FrSky integration cable and Telem UNI cable.
Users browsing this forum: No registered users and 10 guests
