Spirit pro with graupner optic6 2.4ghz radio https://www.spirit-system.com/phpBB3/viewtopic.php?f=35&t=2292 |
Page 1 of 1 |
Author: | slavin89 [ Sun 05. Nov 2017 17:15:36 ] |
Post subject: | Spirit pro with graupner optic6 2.4ghz radio |
Dear to all, i've bought a Spirit pro but I'm unable ti use It with my optic6 radio..wich mode I can match Spirit with my radio? |
Author: | Coco66 [ Sun 05. Nov 2017 18:59:10 ] |
Post subject: | Re: Spirit pro with graupner optic6 2.4ghz radio |
Well, you will probably need a receiver, no? Moreover, is it not the Optic6 a Hitec? |
Author: | slavin89 [ Sun 05. Nov 2017 20:36:04 ] |
Optic 6 is the radio..but I can't use It direcly White Spirit?..I must to Connect Spirit to optima 6 transmitter of graupner? |
Author: | slavin89 [ Sun 05. Nov 2017 22:18:21 ] |
Sorry I wrong title..i tell about hi-tech not graupner |
Author: | ZeXx86 [ Sun 05. Nov 2017 23:32:57 ] |
You can use Spirit units with basically any radio including your. Usually PWM connection is working with all. It is only dependent on your receiver capabilities. What is your receiver? |
Author: | slavin89 [ Mon 06. Nov 2017 9:06:28 ] |
I use optima 6 receiver bit wich Channel i must to Connect ?..And the Spirit must be' programmed in ppm mode? |
Author: | ZeXx86 [ Mon 06. Nov 2017 9:46:53 ] |
Optima 6 receiver has support for PWM connection, so you have to connect it according the PWM scheme: http://manual.spirit-system.com/index.p ... _.28PWM.29 It should be: RX.....SPIRIT ------------------ Ch 1.....AIL (ELE/PIT/AIL port) Ch 2.....ELE (ELE/PIT/AIL port) Ch 3.....Your ESC Ch 4.....RUD port Ch 5.....AUX1 port Ch 6.....PIT (ELE/PIT/AIL port) |
Author: | slavin89 [ Mon 06. Nov 2017 10:50:03 ] |
Sorry but I don't understand ..servo and esc are connected on Spirit and Spirit connected to receiver with One cable or all servo are connected to receiver? |
Author: | ZeXx86 [ Mon 06. Nov 2017 14:01:36 ] |
As you can see on the scheme, ESC is connected to the receiver. Servos always to the unit (ports CH1, CH2, CH3, CH4). Ch 1 - Ch6 that I have written are from receiver. |
