It is currently Sun 24. Nov 2024 23:09:06
PostPosted: Sun 05. Nov 2017 17:15:36
Dear to all, i've bought a Spirit pro but I'm unable ti use It with my optic6 radio..wich mode I can match Spirit with my radio?
PostPosted: Sun 05. Nov 2017 18:59:10
Well, you will probably need a receiver, no?
Moreover, is it not the Optic6 a Hitec?
PostPosted: Sun 05. Nov 2017 20:36:04
Optic 6 is the radio..but I can't use It direcly White Spirit?..I must to Connect Spirit to optima 6 transmitter of graupner?
PostPosted: Sun 05. Nov 2017 22:18:21
Sorry I wrong title..i tell about hi-tech not graupner
PostPosted: Sun 05. Nov 2017 23:32:57
You can use Spirit units with basically any radio including your.
Usually PWM connection is working with all.
It is only dependent on your receiver capabilities.
What is your receiver?
PostPosted: Mon 06. Nov 2017 9:06:28
I use optima 6 receiver bit wich Channel i must to Connect ?..And the Spirit must be' programmed in ppm mode?
PostPosted: Mon 06. Nov 2017 9:46:53
Optima 6 receiver has support for PWM connection, so you have to connect it according the PWM scheme:
http://manual.spirit-system.com/index.p ... _.28PWM.29
It should be:
RX.....SPIRIT
Ch 1.....AIL (ELE/PIT/AIL port)
Ch 2.....ELE (ELE/PIT/AIL port)
Ch 3.....Your ESC
Ch 4.....RUD port
Ch 5.....AUX1 port
Ch 6.....PIT (ELE/PIT/AIL port)
PostPosted: Mon 06. Nov 2017 10:50:03
Sorry but I don't understand ..servo and esc are connected on Spirit and Spirit connected to receiver with One cable or all servo are connected to receiver?
PostPosted: Mon 06. Nov 2017 14:01:36
As you can see on the scheme, ESC is connected to the receiver.
Servos always to the unit (ports CH1, CH2, CH3, CH4).
Ch 1 - Ch6 that I have written are from receiver.
