It is currently Fri 22. Nov 2024 3:10:34
PostPosted: Fri 09. Jun 2017 16:51:28
I test flew the Aero today in my Millennium Master, Heading Hold works beautifully, in Stabilize Mode or Self Leveling it returns to horizontal (ele) well... but when rolled to right and released it gets close to level and sorta stays there.. but when rolled to left it snaps back to wings level perfectly, I'm running separate channels on the ail servos... this is more than likely a simple adjustment but I'm not sure of what? Any help would be great... don't want to just poke around!
Thanks, RidgeMan :?:
SOLUTION: When in Stabilize/Normal the plane comes back to wings level rather slowly even with a high gain setting.
When in Stabilize/Rescuethe plane snaps back to wings level immediately even at low gain setting and "Rescue Inclination" can be adjusted.
I guess I should have read the instruction more closely!
PostPosted: Sat 10. Jun 2017 16:32:16
am I right you have sorted the issue?
I am glad that it is flying now!
If something is not precise (not equal to both sides) you might try to use Trim flight function which can be activated in the flight.
Once landed you can save the values and everything should be done.
PostPosted: Sat 10. Jun 2017 16:44:25
Yes ZeXx86, I think I have sorted thing out... this unit really has a lot of options/settings, that take a bit to get your head around... but I can see them being very useful once understood... you've been great in support of this! Once I switched to Stab/Rescue it performed perfect. I am now comfortable with my understanding. It's coming out of my test plane and going into the plane I bought it for... a 30cc gasser. The test plane was a very light foamie which I flew today in a lot of wind and the Aero kept the plane very stabile... AMAZINGLY stabile!! Thanks for the help!
Users browsing this forum: No registered users and 19 guests
