It is currently Fri 22. Nov 2024 2:41:45
PostPosted: Wed 11. Jan 2017 18:10:38
I would like to know if the rescue function increases the throttle output from the unit to maintain the speed of the airplane during ascend, in order to avoid a stall, or it is necessary that the pilot manually accelerates the motor to keep the air speed
Thank you
PostPosted: Wed 11. Jan 2017 19:03:18
you will need to add mix for the throttle for this operation - When Rescue is active -> add throttle.
This should be easy to do.
But for all receiver connections where throttle is connected to the unit it is technically possible to do.
So we can implement it in the next update.
PostPosted: Thu 12. Jan 2017 18:21:19
Thank you very much, I hope that the next update will include this function
Users browsing this forum: No registered users and 12 guests
