It is currently Thu 24. Oct 2024 1:28:06
[ 4 posts ] |
Yogi43
Posted: Sun 20. Oct 2024 11:57:07 |
Hi, actually I'm setting up the Spirit Aero in a Freewing Avanti v2. When setting the flaps it is required to give 3mm elevator down. Is this also possible in normal mode? I assume in heading-lock mode it is not required. But how does the Spirit behave in normal mode?
The separate flaps are controlled by the receiver directly-
Yogi43
Posted: Mon 21. Oct 2024 12:52:06 |
No idea? The next day with good weather conditions I just will try it out. I have defined a trim switch so that I can set the mixing on elevator to zero in case of any problems.
Posted: Wed 23. Oct 2024 13:23:53 |
it should work well if the Flaps are controlled from the Receiver directly. Will work with HL or Normal mode.
Yogi43
Posted: Wed 23. Oct 2024 16:45:35 |
Hi, thanks
should work means that no elevator mixing is required in HL? What about the mixing in Normal mode?
[ 4 posts ] |
