Version 1.2.0 was released!It brings many new features and improvements:
- Support for μSpirit unit:
- Full support of the µSpirit.
- Compatible with all peripherals.
- Can be used on planes with sub-micro to mini servos with max. current 1.5A.
- IMPORTANT: Older firmwares are not supported!
- Graupner HoTT integration:
- ESC Telemetry support.
- Telemetry connection is active also when the telemetry cable is disconnected.
- USB interface can be connected once you will select the USB connection in the Expert menu (integration).
- Support for μSpirit.
- Added new Telemetry variable - Throttle PWM [ms] - reported under Climb rate.
- OpenTX Integration:
- Significantly faster telemetry data refresh rate.
- USB interface can be connected without repowering the unit - once integration cable is plugged off, the status led will be turned off and you can plug in the USB interface.
- New diagnostic script for displaying channel values - script diagnostic.lua.
- Full support for the Log Viewer - script logviewer.lua.
- Added new Telemetry variable - Throttle PWM [µs]
- JETI Duplex Integration:
- Telemetry data rate was optimized.
- In-Flight Vibration Analysis:
- FIX: Can be used with F: Stabi function.
- Can be activated all the time with no downside effect.
- ESC Telemetry:
- Support for telemetry data from the ESC - all data can be displayed directly in your radio.
- Available for JETI Duplex, FrSky/OpenTX, Graupner HoTT.
- Castle Creations Phoenix and Edge:
- Battery Voltage
- Battery Current
- BEC Voltage
- Consumed Capacity
- ESC Temperature
- RPM
- HobbyWing Platinum V4:
- Battery Voltage
- Battery Current
- Consumed Capacity
- ESC Temperature
- RPM
- Scorpion Tribunus:
- Battery Voltage
- Battery Current
- BEC Voltage
- Consumed Capacity
- ESC Temperature
- RPM
- Kontronik Kosmik and Jive Pro:
- Battery Voltage
- Battery Current
- BEC Voltage
- Consumed Capacity
- ESC Temperature
- RPM
- Kontronik Jive:
- Battery Voltage
- Battery Current
- BEC Voltage
- Consumed Capacity
- ESC Temperature
- RPM
- Added Imotor Shunt parameter - correction factor of the Current/Capacity.
- Added RPM - Sensing Divider parameter for a proper RPM calculation.
- NOTE: All telemetry guides are available at the Wiki pages.
- Wifi-Link module:
- Support for the latest 1.2 firmware.
- Support for the ESC Telemetry.
- Support for the μSpirit.
- Improved detection of the firmware version with more clear messages.
- Spirit Settings - Android:
- Spirit Settings - FreeBSD:
- Launch scripts for better architecture detection updated.
- Stability was enhanced.
- Manual:
- Pin layout for Spirit and µSpirit units is available.
- Spirit Aero software:
- News noticement:
- Automatic noticement of a new available updates.
- ChangeLog:
- Scrolling in the changelog window to allow displaying a longer text.
- Improved Setup Wizard:
- New schemes with μSpirit.
- Improved detection of the unit swapping.
You do not have to change any settings after the update from previous version.
Update for the
Spirit units,
Wifi-Link and
OpenTX Integration is available in our
Download section.
