It is currently Fri 22. Nov 2024 0:51:10
PostPosted: Sat 31. Oct 2015 20:33:09
Hallo,
I think it would be useful when the Spirit would handle the Failsave on Throttle
in PPM - Connection in the same Way as in the several BUS - Connections.
I use a Jeti RSat2 in PPM-Mode and need also Telemetry, so there is no way
to connect Sprit via EX-Bus (exept buying new REX-Receiver). Would this be possible?
Thanks Bernd
PostPosted: Sat 31. Oct 2015 21:16:27
you can configure Failsafe in Jeti transmitter. Failsafe is supported with PPM as well.
Actually Jeti Rsat2 support EX Bus connection as well, which is much better solution.
PostPosted: Sat 31. Oct 2015 22:46:15
Thanks for quick response. I know about the possibility of using EX Bus. It works well, also when the
Cable between Rx and Spirit breaks. But EX Bus only is available at Ext-Port, so the Option of Telemetry
is not more given (with RSat2).
If I use PPM and configure Failsave in the RSat2 it works also, with the Exception of a Cable-Fail. I proove
it, but the Motor (of course) stay running. Would it be much work to implement Failsave at PPM in the
same way as in EX Bus (taking the Throttle Failsave-Value on Initialisation)?
Best Regards Bernd
Users browsing this forum: No registered users and 35 guests
