It is currently Fri 22. Nov 2024 1:17:13
PostPosted: Sun 18. Jun 2023 10:34:46
Hi!
I have an issue where I can't switch on/off the Ch0 Output with Channel 8 of the radio.
I'm using a Spirit GTR with a Jeti DS12.
In the Receiver Output window the state is always 'ON', no matter if I set max negative to -150% or not. It never changes to 'OFF'....(See Screenshot)
Also, if I measure the output voltage on Ch0 it is at 1.25V and 2V respectively, which is also somehow weird.
Did anyone ever had such an issue?
Thanks!
PostPosted: Wed 21. Jun 2023 5:45:36
have you tried connecting servo at the Output?
It is not outputting analogue voltage signal, but PWM signal with channel value. So there is no On or Off.
PostPosted: Tue 11. Jul 2023 20:06:20
Thanks for clarifying this!
Yes, PWM is at the output.
I had it in my mind, because the Jeti receivers have this function. So, I then misinterpreted the options....
Do you think that this feature could be implemented?
Thank you!
Users browsing this forum: No registered users and 54 guests
