It is currently Fri 22. Nov 2024 0:55:57
PostPosted: Fri 14. Apr 2023 21:31:59
Spirit Settings application only allows a single instance to be opened. This makes copying settings tricky. Can it be changed so that multiple instances can be opened, and if an instance is already connected to USB, open the 2nd in demo mode instead.
PostPosted: Sat 15. Apr 2023 7:31:05
what settings do you need to copy?
If you need to copy settings from one unit to another, why you will just not save the files and then open them in the second unit?
This process takes just few seconds and can't go wrong.
PostPosted: Sat 15. Apr 2023 14:13:32
I've changed receiver type from sbus to fport. All channel settings and stabi settings were lost so I'm trying to copy from a recent backup.
Users browsing this forum: Bing [Bot] and 39 guests
