Spirit System
6 degree adjustment does not work with Jeti Integration
https://www.spirit-system.com/phpBB3/viewtopic.php?f=24&t=4809
Author:  commonrailer [ Sun 01. Aug 2021 12:00:45 ]
Post subject:  6 degree adjustment does not work with Jeti Integration
Hi Tomas
Maybe it is already wellknown by you :P ….
Today I noticed that the 6 degree value is not adjustable with Jeti integration 3.2.2
All other parameters are adjustable so far.
With Win PC application all works fine including 6 degree adjustment.
Same behavior on all Helis (equiped with Spirit red, Pro, II and RS)
Best regards
Walter
Author:  ZeXx86 [ Thu 05. Aug 2021 21:53:45 ]
Post subject:  Re: 6 degree adjustment does not work with Jeti Integration
it is adjustable. Nothing changed for a few years there.
Can you explain what do you think is wrong?
Please make sure to use correct integration file with correction firmware version.
Author:  commonrailer [ Sat 07. Aug 2021 7:04:35 ]
I have in Jeti transmitter the 3.2.2 Integrationfile and in the FBLs the 3.2.2 Firmware.
It is no problem to editing the 6degree value in the transmitter, but there is no mechanical movement on all Swashplate servos.
Normally if you edit the value the servos jumps to the corresponding position and following the parameter change.
But in my case: nothing happens.
With PC software it works perfect.
Author:  ZeXx86 [ Tue 10. Aug 2021 10:13:32 ]
You have to click at the >> Geometry 6° (tuning) ;)
Author:  Bolan [ Mon 23. Aug 2021 8:48:58 ]
Have seen this problem several times - so it is real. Sometimes it works sometimes it does not. The work around for me has been to enter the setup via the setup wizard.
Author:  ZeXx86 [ Mon 30. Aug 2021 13:33:43 ]
It is always required to click at the Geometry 6° label. Only then the unit will switch to the special mode where swashplate is tilted and you can see the actual value.
Otherwise it is only changing configuration with no visual checkup.
http://www.phpbb.com/
