Support for Ubuntu 20.04 https://www.spirit-system.com/phpBB3/viewtopic.php?f=24&t=3928 |
Page 1 of 1 |
Author: | eraserix [ Fri 01. May 2020 20:16:34 ] |
Post subject: | Support for Ubuntu 20.04 |
I recently upgraded my system to Ubuntu 20.04. Apparently, Ubuntu no longer provides Qt4, which makes it impossible to start the Spirit configuration software (3.0.0). (Qt4 was dropped from Debian: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=953294) Code: $ ./settings.sh
./settings-x86_64: error while loading shared libraries: libQtGui.so.4: cannot open shared object file: No such file or directory $ ldd settings-x86_64 ✘ linux-vdso.so.1 (0x00007ffed3bcb000) libQtGui.so.4 => not found libQtNetwork.so.4 => not found libQtCore.so.4 => not found libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f1a1bcb2000) libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f1a1bad1000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f1a1b982000) libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f1a1b965000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f1a1b773000) /lib64/ld-linux-x86-64.so.2 (0x00007f1a1bcec000) |
Author: | ZeXx86 [ Sat 02. May 2020 7:43:16 ] |
Post subject: | Re: Support for Ubuntu 20.04 |
Thanks for the report. It will be fixed very shortly for upcoming new 3.0 version. |
Author: | tysonfromcanada [ Sun 27. Sep 2020 19:35:20 ] |
Hi guys, I installed qt4 on my ubuntu 20.04 and the tool works fine now. Found the instructions below: https://askubuntu.com/questions/1234786 ... untu-20-04 |
Author: | ZeXx86 [ Sun 27. Sep 2020 19:42:02 ] |
Hello, no need to install anything. Just start: settings.sh script and everything should work. |
Author: | tysonfromcanada [ Sun 27. Sep 2020 20:30:29 ] |
I kept getting an error until I installed the qt4 libraries.. fairly fresh default installation from a couple of days ago. Any idea what else I could have been doing wrong? |
Author: | eraserix [ Wed 21. Oct 2020 16:35:22 ] |
It works on my Ubuntu 20.04 installation. I had to install libaudio2, but nothing more. Qt4 is bundled with the Spirit software, so no PPA required. |
Author: | ZeXx86 [ Wed 21. Oct 2020 17:01:44 ] |
Thanks for the report. What error are you getting when starting the software? |
